Henry Farley
  • Content Count
    3
Community Reputation
0 Neutral
Personal Information
  • First Name
    Henry
  • Last Name
    Farley
  1. Hi Chis, I fear that this situation may be my doing. When I became aware that a new constitution might be presented to this year's AGM I initially alerted my District Councillor and later the MYA Secretary to Council, to the potential pitfalls of presenting it as a single motion. Such a complex document will inevitably attract amendments and if the number of those is anything but very small the voting form for postal and email votes become very large and not sensibly handled at an AGM. It has to list all possible combinations of the motion and the amendments and this escalates very quickly with the number of amendments. I hoped and presumed that Council would not present the constitution as a single motion but deal with the changed topic one by one. However Council have found an alternative solution to the problem of amendments by presenting it to an EGM under the rules of which there is no provision for amendments. We now have take it or leave it options. I found it hard to understand what has changed and there has been no explanation of that, the need for changes or the benefits to be gained from them To assist me I have produced a table listing what I perceive as the differences. It is based on the order of the current constitution with deviations where I found them useful and relevant. I doubt that I have found everything and there are no doubt errors of one sort or another but I though it better to publish quickly. Perhaps the most important change is the introduction of appendices which Council can change without reference to the membership. Some of those, such as rules and regulations covering racing events, have always been dealt with that way but others are more fundamental. Of particular interest to you and I is the intention to introduce Terms of Reference for VPs! Hopefully some will find it useful so it is attached Cheers Henry 2020 constitution review.pdf
  2. Darin, As one of those volunteers that produce some of the things you have listed in your second paragraph, I give my effort freely and willingly as I’m sure do all the other volunteers. I see no connection between what we do and the bank balance. The value placed upon those things listed will vary between members depending on how much they are of direct benefit to them. Once again there is no obvious link with the bank balance. That balance has more than doubled over the last 7 years with nothing to show for it and no plans evident to spend it in ways that will benefit the majority of members. The amendment sought to give the benefit directly to all members by reducing the subscription level to lower that balance to a more realistic level. It is not ‘something for nothing’ as the members provided it in the first place. To answer Ian’s point – there is no cost in returning it to the members as it would be achieved by not asking for quite as much in next year’s subscription. Henry Farley One of the authors of the amendments
  3. I don't get here often so have only just noticed Shaun's plea. It looks like a Panther to me. The nut on the fin bolt is just like one on a Panther that one of my club mates bought via Ebay a while ago and is currently getting down to the design weight. It was a kilo too heavy. By attacking the hull inside with a dremel and sanding drum, cutting holes in the deck and removing vastly over engineered servo mounts plus a jib twitcher he was almost there. A bit of work on the ballast completed the job. Now waiting for the weather to warm up a bit then we can measure it. The hull is chopped strand mat and a bit vulnerable in places after the sanding, so he had to patch the inside where it got too thin. Luckily I had measured one years ago so was able to compare to be sure that it is a Panther. Designed and built by Roy Morgan and distributed by Jim Fewster in Hexham, Northumberland. The one my club mate has was solid to the bow so he has cut that off and fitted a silicone bow bumper. Details from the original advert. LOA 59.75 inches LWL 40.9 inches Weight 26.42 lbs Fitted with 5/8 ID mast tube. Our local one had a stainless steel fin bolt through an aluminium alloy tube in the foam filled fin. Thoroughly corroded together so came out in one piece! Tube now brass and 6mm stainless studding used in place of bolt with threaded ends Henry
