Sign in to follow this
MarkG
Help to identify a yacht. Possibly Tony Abel.
Hi All,
I'm a long time RC aircraft flyer with a hankering to try sail, so when an elderly friend offered me his old yacht I accepted gratefully.
It is 8 ft. from keel to mast top and 50 inches bow to stern. Glass hull, sails by P J Sails.
It has not been in the water for years and will need a bit of fettling before it gets wet again.
My friend couldn't tell me what model it was or which class it would fit into.
I found a Tony Abel card in the hull and it also has a Tony Abel sail winch servo.
Any help appreciated.
Mark.
Edited by MarkG
If the hull is 50 inches long, the yacht is almost certainly a Marblehead of some design, although I don't know which. Don't think it is a Moonraker, which was kitted by Nylet. Frank Parsons at Nylet could probably confirm that either way. Think there was a "Kingfisher" design around , as well.
Despite the card and the winch, it may not actually be a Tony Abel boat.  I bought a Vic Smeed designed "Harem" Marblehead some time ago  which was advertised as Tony Abel boat, simply because it had several of his stickers attached!.
Edited by tiggy_cat
Hi
Thanks for that. I did occur to me that it may not actually be by Tony Abel, I've edited the title.
Perhaps I'll contact Nylet.
Thanks.
Mark.
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
